TE-20 engine parts
1031D
11-06-2007 19:52:44
I have a TE-20 with a Z-120 engine with the washer type front thrust bearing, and I am looking for an overhaul kit and camshaft. I found kits that have everything in them that I need, but they say they are not for engines with the washer type front thrust bearings. Will these parts work on the different engine with the exception of the thrust bearings?
gshadel
11-07-2007 06:04:15
 Re: TE-20 engine parts in reply to 1031D, 11-06-2007 19:52:44
1031...
Sounds like your on the right track, so I apologize if you are already up to speed on all of this stuff. Your Z120 engine originally had front bearing shells with a flange, and no thrust washer. The Z129 used a straight front bearing with no flange, but with a thrust washer. The same rebuild option is available, and commonly used, for the Z120, ie. a straight front bearing shell with a thrust washer. Absolutely everything else is the same, it's just that front shell & washer combo. I would venture to assume that someone has been inside your TE engine before, and replaced the original flanged bearing with the straight bearing & washer. Sounds like maybe your looking at rebuild kits that utilize the original style flanged front bearing, so you would not need the thrust washer. But all the other parts are the same and will work with either bearing type. This site sells rebuild kits for your Z120 engine with either bearing style, so you can choose to stick with the straight shells and thrust washer, or switch to the flanged bearing with no washer. Totally your call, I don't think one design is better than the other. Assuming you already know this, but you can buy rebuild kits with, or without crank bearings. Make sure you need'em before you buy'em. The manual has spec's for bearing wear that you can check pretty easy with plasti-gauge thread, available at any car parts place. Sounds like your getting ready to spend a big chunk of $$$, just 'cus your doing a full rebuild, don't assume everything needs replaced, it could save you some money.
Been there, done that.
George
1031D
11-07-2007 08:29:43
 Re: TE-20 engine parts in reply to gshadel, 11-07-2007 06:04:15
Thanks for the help. I tore the drive gear off of the cam for the distributer, so I pulled the motor to freshen it up as I bought as a running working tractor that had been overhauled at some time in it's life. I have gotten into the habit of just replacing all of the wearing components just as a piece of mind issue. I have one sleeve out of round by .010"+ and it had a little bit of an oil pressure problem which I think I tracked down to a bad bushing on the drive shaft for the pump. I just want to put it together and put it back into the fields once again.
Jeff-oh
11-07-2007 05:04:38
Call Jerry Moons at Monte Equipment. He is probally the most knowlegible on the Contential Engine Variations.
1-800-228-2625
He'll also have the best lead for the parts you need.
