Dynamo -+ earth?
Rob
03-03-2001 11:31:44
The reconditioned lucas Dynamo on my TEA 20 has a red tag on the main connector I assume this means it is a Negative earth Dynamo but the tractor is Positive earth, Does this matter? and can i re energise it as a positive earth Dynamo by "touching the field connector to (another connector) for a second trick" - but to which connector? Thanks, Rob
stevie_alc
03-03-2001 20:46:03
 Re: Dynamo -+ earth? in reply to Rob, 03-03-2001 11:31:44
Red would be positive and Black would be negative.
If you have a 6 voly system with a generator then you have a positive ground system. If you have 12 volt with an alternator then you use negative ground.
stevie_alc
03-03-2001 20:45:28
