Main brake pedal OK, but have to PULL for left and right??
motorv8N
11-14-2007 19:35:10
Here's a mystery. The chap who sold me this 51 TEA 20 said he replaced the brake shoes and indeed it stops just fine using the main brake pedal.
However, the left and right pedals are so stiff that standing on either one with all my weight barely moves them and there is no appreciable braking action.
Stranger still, if I reach down and pull up on the foot pad of either, the pedal will move freely and the brake will stop its associated wheel. ]
Does anyone know how this can be? I've carefully traced the linkages and they all seem straight, loose and in their proper places. I thought perhaps he connected a linkage backwards but I can't find evidence of it.
motorv8N
11-19-2007 20:01:52
 Re: Main brake pedal OK, but have to PULL for left and right in reply to Bob (Aust), 11-14-2007 19:35:10
John (UK) said: (quoted from post at 23:13:07 11/19/07) ...without knowing which type you have can't be more definite...John
Thanks, John -- would a photo help? If you can tell me what perspective would tell you the type of brakes, I will post it. Also, you mention springs. Are these external or something inside the drum?
John (UK)
11-19-2007 14:13:07
 Re: Main brake pedal OK, but have to PULL for left and right in reply to motorv8N, 11-14-2007 19:35:10
Check that the brake springs are fitted correctly and also check the independent brakes are not seized at the end near the axle as they should work in both directions. Also the brake rods may need resetting as a lot of people try to adjust the brakes with these and make a holy mess of the adjustments.There are two types of brakes fitted on these tractors and without knowing which type you have can't be more definite...John
motorv8N
11-15-2007 09:17:22
Looks like I need to get me a shop manual for this thing.
Gerald J.
11-15-2007 21:32:35
 Re: Main brake pedal OK, but have to PULL for left and right in reply to motorv8N, 11-15-2007 09:17:22
And the parts book which shows every assembly exploded that the shop manual often doesn't.
Gerald J.
Gerald J.
11-14-2007 20:05:13
Sounds like the cam is in the wrong position inside the brake drums.
Gerald J.
