starter
Archie in KY
11-18-2007 10:40:38
My TO-35 won't turn over. I charged the Bat and tested the solenoid with a test light. Took the starter off and jumped it, from the terminal to + pole on Bat, from the body of the starter to - pole on Bat, nothing. Can someone give me some suggestions on repairing it?
Archie in KY
11-18-2007 14:58:15
 Re: starter in reply to Archie in KY, 11-18-2007 10:40:38
As I was tighting down the nut where the wire connects the stud turned about a qurter turn so Phil may have hit the nail on the head. I will check in the morning. If thats not it I am off to the NAPA store.
phil(va)
11-18-2007 13:49:20
If you have absolutely nothing on a bench with known good 12 volt battery, my money is on a bad connection to the top post, inside the case. The top post has two nuts, one to hold it to the case, and the other to hold the cable. Often they get over tightened and the post rotates inside and the soldered connection becomes loose. Check your top post and see if it is a little bit loose. If so, that"s probably it, although you got some great advice otherwise as well. If you have not worked on these before, you might want to take it to an automotive electrical repair shop. They are usually very reasonable.
Jerry/MT
11-18-2007 11:52:50
Check the brushes, replace if necessary and clean the commutator. Check the field coils for an open circuit. if the field coils are open then you"ll need to replace them.
The other alternative is to take it to an autoparts store or an auto electric shop that has the ability to test it.
