Ferguson disk parts
TJ in IN
11-25-2007 17:24:06
Just pick up a ferguson 6' three point disk AB0 22 at aution and got home and noticed bearing housing on front was cracked. Any ideas where to get part for this?
MF Poor
11-26-2007 08:30:06
 Re: Ferguson disk parts in reply to TJ in IN, 11-25-2007 17:24:06
So long as you don"t have the wooden bearing, the same part from a model #25 disc may interchange. I believe that part is still available. You MIGHT have to get both halves and a matching spool. Also, check tractor bone yards. There were thousands of those disc"s sold. Bound to be a few parts donors around somewhere.
chuck bergstrom
11-26-2007 06:16:17
We need a little more info. The ABO was sold with
either wood bearing, or steel spool to steel cap.
Also do you need top or bottom part. Chuck
phil(va)
11-25-2007 19:12:01
Scott at Sweigard Bros, in PA may have it. You can get his phone by searching this site. He monitors this site as well as Ford.
Ken Crisman
11-25-2007 17:39:22
I don't know if Dearborn parts will work or not , but there's a guy over on the ntractor board who says he has parts for plows & discs . His name is Scott . This site has a filter that doesn't allow other sites mentioned so add the word club after tractor when ya try it . Good luck & God bless, Ken
