Gerry UK
12-15-2007 07:21:23
I have owned a Feb 1948 TEA 20 for two years (it had previously been garaged and not used for around 20 years) and have fitted the following new parts - battery, points, condenser, rotor arm, plugs, distributor cap and leads, key switch, gear lever starter switch, coil, starter motor, carb kit, fuel filter. Have cleaned out fuel system and air filter, changed all oils and hoses. Set everyting up as described in service manual and from these notice boards.
I have managed to Top a few acres with it this year, had it running for about two hours at a time, but have never managed to get it running smoothly yet. Recently it has been running worse, difficult to start, low power, flames from the exhaust so have been trying to set up the timing and I noticed that there is some movement of the distributor and the spark is inconsistent, sometimes good, sometimes bad.
If I hold the rotor arm (new and fits tightly) and twist the distributor clockwise and anti clockwise it will turn approx one sixteenth of an inch either way. If I try rocking the distributor from side to side there is movement of approx 20 thou in.
Does this sound as if it needs replacing and if so, are there recon units available? Any advice will be gratefully received!
