Ferguson wiring
pooch
12-24-2007 21:04:03
My son just bought a Ferguson,(1949) TO-20, that has set up for the past few years. The engine is loose but the wiring is a mess and I have been given the job of trying to sort it out.I really need to knoe if it s pos. or neg. ground, and how des the start switch wire up? Any info will be greatly appreciated. Thanks, Frank
Bob (Aust)
12-25-2007 13:23:07
 Re: Ferguson wiring in reply to pooch, 12-24-2007 21:04:03
Pooch. The TO20 wiring diagram is available on the FENA web site.
Branlin
12-25-2007 08:47:58
 Re: Ferguson wiring in reply to John(UK), 12-24-2007 21:04:03
I have a question about the manuals.
Listed on this page are two separate items:
Ferguson TE20, TO20, TO30 Service Manual 197 Pages (Part No: MH-S-MFTE20)
Ferguson TO20 Service Manual 197 Pages (Part No: MH-S-MFTE20)
The part numbers and prices are the same. Are they the same book?
Brent, IN*
12-25-2007 08:18:45
Welcome to the wonderful world of Ferguson and Merry Christmas! You will want to get a factory service manual (available on this site). A wiring diagram is in the manual as well as just about anything you need to know about the mechanics of this machine. There is also a Ferguson club called The Ferguson Enthusiasts of North America (FENA). This is a great organization full of knowledgeable people. You will receive several newsletters each year as well and only costs $15. The web address is : www.fergusonenthusiasts.com I just checked and the site is temporarily not available. Must be doing some maintenance or something. Best of luck!
HillsOfTn
12-25-2007 04:00:24
Does it still have the generator or has someone in the past replaced it with an alternator?
Bruce(OR)
12-24-2007 23:36:54
Should be 6V pos ground. (Better spark at the plugs with the Pos goround.) Ignition switch is 4 positions.
1) off
2) Ign
3) Ign and lights
4) lights
pooch
12-25-2007 11:24:33
 Re: Ferguson wiring in reply to Bruce(OR), 12-24-2007 23:36:54
Thanks for the info. I will check on the service book. The generator is still on the tractor but I will probably convert to 12 volt and go to an alternator. Again, thanks for the info and have a very Merry Christmas and a Happy New Year. Jesus is the reason for the season.
Jerry/MT
12-25-2007 12:55:21
 Re: Ferguson wiring in reply to pooch, 12-25-2007 11:24:33
RE: Coil Polarity
Actually the the small wire from the coil to the distributor should have the same sigh as the ground on the battery. When you convert to a 12V alternator, it will have a negative ground so that the small wire from the coil to the distributor should be on the negative (-) terminal at the coil. By the way, the coil will need replacementunless you add a resistor to the 6V coil if you go to 12V. The NAPA IC-14SB coil (~$15) does not require an external resistor. If you want to keep the 6V coil you must use a current limiting resistor in series with the coil wire to limit the coil current to 4 amps maximum.
