what model lucas starter for te20 continental engine ?
john[mo]
12-27-2007 15:11:24
what is the lucas model number for my te 20 with the continental engine?
john[mo]
01-09-2008 17:47:58
 Re: what model lucas starter for te20 continental engine ? in reply to john[mo], 12-27-2007 15:11:24
i saw one on ebay and was not sure if it was the correct one for my tractor. it was new and would have been a good spare for the price. mine is working fine so if it goes bad i will see if i can find a starter rebuild shop.
eugene stevens
01-09-2008 16:00:18
John, late seeing your question on lucas starter.mine went bad on 1948 te20 took to starter repair shop rebuilt it for less than half price of new one ,starts great good luck.
Mark Stough
12-28-2007 08:45:08
If you definately have to have a Lucas for authenticity I can't help you. But if you are looking for a new starter that will fit I have one. I had one made for a TE-20 several years ago (cost me almost $200) when I was having starting problems. Turned out that the starter was not the problem so I took it back off. It was on the tractor about a month. This is a Delco starter with the correct nose piece to properly bolt up to the TE model with the Z-120 engine. If you are interested please contact me. I am located in the St. Louis, Missouri area.
Bob (Aust)
12-27-2007 18:25:45
John
"It is not Lucas 25002F / M35G 1 L3 as that is the 12 volt starter for the TEA20"
Sorry, not a hope it will fit your TO20 or TE20. The M35G 1 is 12 volts, no "bullet head" to support the end of the armature shaft and the Bendix pulls back towards the starter motor, not forward like I think the TO20 and TE20 starters.
Lucas M35G 1 from my TEA20:
third party image
john[mo]
12-27-2007 17:57:40
the reason i asked is that i saw a lucas MG35G1 for sale and wondered if it would fit my te20
john[mo]
12-27-2007 17:52:41
i was wondering if the delco starter would work. are the flywheels the same in a to20 and te20? was the bellhousing the difference in which starter would work? what about changing the distributors? i thought i read somewhere that the te20 had a different ringgear in the rearend than the to20. supposed to have a little better pulling power with a te20.
Bob (Aust)
12-27-2007 17:52:41
Sparex list the replacement TE20 starter motor part number as S60354 (6 or 12 volts????), Bare-Co as part number B7200 (12 volt replacement), although Bare-Co show a solenoid mounted on the starter motor.
third party image
It is not Lucas 25002F / M35G 1 L3 as that is the 12 volt starter for the TEA20, which is totally different.
Duner may be on the money, Lucas P/N 25505, as the TE20 (Continental engine) finished production in 1947. Lucas P/N 25519 1948-51 would be the 6 volt starter to fit the Standard engine.
fergone
12-27-2007 17:27:52
You can use a Delco you have to grind the starter nose and do some grinding in the bellhouse. my dad work for Ferguson and did this to a Te20 I sure would like to have that tractor now It had a 35 seat gray/green paint Z129 head the ferguson tractormeter It would sure out work a To20
Duner Wi
12-27-2007 16:15:03
Here is what my book says. 1946-47 Lucas #25505.
1948-51 25519. Fits the British Massey Ferguson.
I know it was Harry Ferguson till 54-55 or so.
