TEA 2085 Ampmeter installation
GrG
01-02-2008 16:24:58
Does anyone know of site that would have a wiring diagram to install a ampmeter on a TEA 2085 ,this way I will know if the generator is charging correctly.Any info on testing a Lucas Generator would also be helpfull.
John (UK)
01-03-2008 10:12:38
 Re: TEA 2085 Ampmeter installation in reply to GrG, 01-02-2008 16:24:58
Fit a voltmeter across the terminals of the Generator and start the engine, rev the engine SLIGHTLY and it should show 12volts at fairly low revs, if the voltage fluctuates or doesn't reach 12 volts then the Generator should be checked.
To fit an ammeter to your tractor, it should be fitted in the cable between the starter switch terminal (the one with the lead from the battery on top of the Clutch Housing below the battery) and the "A" terminal on the Regulator. If you need the wiring diagram, just email me at:- fergusontractors@tiscali.co.uk
tell me what you need and I will send it...John
Jerry/MT
01-03-2008 10:15:33
 Re: TEA 2085 Ampmeter installation in reply to John (UK), 01-03-2008 10:12:38
Glad to see you posting again, John. Hope all is well with you and the Mrs.
John (UK)
01-03-2008 10:38:10
 Re: TEA 2085 Ampmeter installation in reply to Jerry/MT, 01-03-2008 10:15:33
Don't expect too much for a while, feeling better though but still a bit seedy....John
Bob (Aust)
01-03-2008 03:20:05
Here is a very useful link on Amp Meter installation and wiring diagram. This example is for a Pos (+) Earth MGA which is almost identical to the TEA20 installation.
Auto Amp Meter.
Hope that helps!
Bob in Oz
Gerald J.
01-02-2008 22:22:17
Its not complex.
There should at most two wires on the ungrounded battery post. One going to the starter solenoid, the other to the rest of the wiring. That second wire will be smaller probably not over 10 gauge. It may be connected to the solenoid post with the battery wire. Remove that small wire from the battery connection. Connect it to the ammeter + terminal if negative grounded. Connect a new wire at least 10 gauge from the other ammeter post to where that wire was removed. Turn on the lights. The ammeter should deflect negitive. Crank it up and the generator should deflect it positive, then it should taper off to zero after running a while when the battery is fully charged.
Gerald J.
Jerry/MT
01-02-2008 16:53:57
Try www.fergusonenthusiasts.com
