Starting adn running issues with a 52 TE-20
Shawns_52
01-07-2008 06:34:51
Have a 52 TE-20 and having a few problems with it.
The biggest issue is after it has been running for a while, she'll quit. If you're out plowing snow or back in the woods, it'll work for a while (maybe an hour or so) and then just quit. By the time you walk out to get the other tractor to tow it out, she'll start and come out of the woods under her own power.
Seconly, she doesn't have the throttle response it should. Hard to get it to idle down slow and she won't open up.
And the last issue is starting...can't touch the choke until she kicks. Then it starts just fine. Touch the choke too soon and she won't start.
I did read on here about changing the coil to one from NAPA (IC14-SB). It was converted to 12 volt long ago.
Any help would be greatly appreciated as it's going to be in a parade the end of the month and don't really want to have to tow it when it is supposed to be towing the float/wagon.
Jerry/MT
01-07-2008 11:39:51
 Re: Starting adn running issues with a 52 TE-20 in reply to Shawns_52, 01-07-2008 06:34:51
You"ll need to do some diagnostics to figure out what your problem is. Make sure that you points are properly adjusted and are not burned, pitted or corroded.
First look at you coil to see if it is what I call a "phony" 12V coil. It will have some printing on it that says "12V coil, Use with external resistor". If it says that, then look for a resistor in the primary ignition circuit. If you don"t have the resistor, your coil can overheat and short internally, killing the engine and this process takes abour 30-60 minutes. After the coil cools down, the engine will start again only to die agan. This process will continue until the coil burns out at which point it wont start. Next time this happens, quickly pull the center wire out of the distributor cap, hold it near a good ground. If you have no spark that is most likely the problem. The coil will also be very warm to the touch. If this is the problem, you either need to put the required resistor in the circuit or you can relace the coil with a true 12 V coil like NAPA"s IC-14SB(~$15).
The problem with idle and "...she won"t open up" can be cause by incorrect initial timing, centrifugal advance not working or improper carb adjustment/dirty carb and/or weak spark( poorly adjusted points, bad connections in the primary ignition circuit), reduced fuel flow, etc.
"Can"t touch the choke"... problem can be caused by a bad float adjustment or poor carb adjustment.
I"d suggest you get a Ferguson Shop Manual(~$20) and go throught the ignition and carburetion sections and make sure you understand how the systems work and then make the appropriate adjustments to your TE-20.
Then come back to this forum and we"ll help you get your machine running properly.
