Ferguson TEF - Starter Inhibitor Button on Gearbox
Bob Brown
01-07-2008 13:01:21
Can any one tell me how to remove the brass button on the right hand side of the TEF gearbox. The button is preventing the lever going forward as the button moves slightly when the lever is moved. Pressing the button does not allow the gear lever to go into the start position.
tractorsam
01-07-2008 14:41:29
 Re: Ferguson TEF - Starter Inhibitor Button on Gearbox in reply to Bob Brown, 01-07-2008 13:01:21
Is the button oriented correctly? I believe there is a small locating pin which prevents the button from rotating. Could this be causing your problem? tractorsam
Bob Brown
01-07-2008 14:49:48
 Re: Ferguson TEF - Starter Inhibitor Button on Gearbox in reply to tractorsam, 01-07-2008 14:41:29
The slot headed pin is fitted and appears OK. The button pushes in against a spring as you would expect it to but it just does not free the shaft.
tractorsam
01-07-2008 17:28:04
 Re: Ferguson TEF - Starter Inhibitor Button on Gearbox in reply to Bob Brown, 01-07-2008 14:49:48
Have you had the tractor long? The reason I ask is that I found when I got mine that I had a tendency to put the gear stick hard over to the right and try to push forwards to engage the starter. I found that this often did not work (felt like it was locked solid) and that the gear stick needs to be between front center and hard right, kind of had to feel it in there. Might this be your problem? tractorsam
