Box Blade-Zane Thang
Michael William
03-20-2001 07:48:30
OK, here come the questions. I have a TO30 that I want to use to clean up my roads. I got a box blade with the tractor, but I have never used one. I need some suggestions on the best way to get the roads in good shape using the box blade--do I need the Zane Thang? Also, I think I have an over-running clutch already. Looks like a soup can with a spindle coming out the end. Am I right? Thanks for all your help.
Michael Williams
SandyB
03-20-2001 15:11:58
 Re: Box Blade-Zane Thang in reply to Michael Williams, 03-20-2001 07:48:30
Mike,
Sounds like you have an ORC or Overunning Coupler. Twist it the wrong way and it should ratchet just like a ratchet wrench...if it does, you've got one. Yardboxing or Boxblading (we call them yardboxes in the South) will be much more rewarding with a ZaneThang. You'll love the control. There are times, when I'm yardboxing, that I loosen the ZaneThang so that it will be just in draft control. Other times I want the yardbox to be just at a certain height, and the ZaneThang is good stuff. You will want position control for other things you do such as boom poling and Bushogging. You'll like the ZaneThang. And no, Zane doesn't give me a cut.
SandyB
