Ferguson TO20 Hydraulic
Dallas2
02-10-2008 18:18:46
I have a Ferguson to20 and the hydraulic lift seems to lift to high. Is this possable?
Jeff-oh
02-11-2008 06:11:12
 Re: Ferguson TO20 Hydraulic in reply to Dallas2, 02-10-2008 18:18:46
What do you mean it lifts too high? Are you saying the transport position seems to be too high, or that you cannot keep an implement at a height?
In the second case you show know that there is no position control on the TO-20 so maintaing a specific height is difficult, though there are work arounds.
Jeff
Dallas2
02-11-2008 15:31:28
 Re: Ferguson TO20 Hydraulic in reply to Jeff-oh, 02-11-2008 06:11:12
Lower link assembly is hitting the underside of the rear axle housing with a 5' box blade attached.
thanks
Jerry/MT
02-10-2008 19:44:51
The 3 pt lift is self limiting in height.By that I mean as the lift piston reaches it max position, it pushes the control valve to the neutral position which stops the lifting.
