Hydralics
klaus
02-20-2008 11:52:33
third party image
Well, I have a TEA-20 (1948). Was given to as a present. Some idiot have at one point removed the lifting arms and the hand control lever, with an angle grinder I presume.
I decided to dig into it. So I have started by removing the quadrant plate. With it a 10 inch rod came out. When I looked into the hole I could see that the upper part of the hand control fork. I assume it has come off at some point, and the previus ovner took out the angle grinder instead of fixing the problem.
Anybody here experinced anything semilar? I suppose I just have to fish the whole thing out and fit the missing part. If is not lying on the bottom of the gear box.
Jeff-oh
02-21-2008 08:57:52
 Re: Hydralics in reply to klaus, 02-20-2008 11:52:33
Sounds like you may want to pull the lift cover plate and do a through assesment of parts and perhaps even a pump re-build.
