Pump question
Matt L
02-28-2008 00:12:08
So I was messing with the ferg taking it appart and cleaning. Pulled out the hyd pump third party image
Anything I should look at and check out sides the safety valve?
phil fenner
02-28-2008 23:43:25
 Re: Pump question in reply to Matt L, 02-28-2008 00:12:08
Not sure what version of pump you have, but if you want to recondition it before putting in back together, I would recommend you follow the instructions in the shop manual which are too many for this forum, but in general, mic everything for wear and replace if necessary, replace paper gaskets, grind out the valve chambers and thoroughly clean everything.
The relief valve can be replaced but if you know it is working I would leave it.
Phil(WA)*
