1958 ferguson tractor
Lynne Janes
03-03-2008 12:44:01
Hi, I might not have spelled it right but I an trying to find out the value of a 1958 ferguson tractor 25 hp gas unredone. thank you Lynne
phil(va)
03-04-2008 04:39:02
 Re: 1958 ferguson tractor in reply to Lynne Janes, 03-03-2008 12:44:01
In addition to what Bob and Richard said, you might be able to give us enough description by telling us the number on the engine. Does it begin with a "Z" such as Z120 or Z129 or Z134, etc., for instance?
Bob (Aust)
03-03-2008 13:44:31
Lynne. I don't think there was a 25 HP Ferguson tractor produced in 1958.
If made in 1958, I think you may have a TO35 which is varies from 32.8 to 35.0 HP, depending on engine??
What is the serial number? The Serial Number is located on the dash, a 2x3 inch plate attached with rivets.
Is it gasoline or diesel? What condition? Where is it located?
I'm sure someone here can give you an idea of value, but not without all the tractor information.
Bob in Oz
Richard L
03-03-2008 13:56:50
Lynne I am not one that can tell you what it is worth. However some of the others may be able to tell you but first they will need to know what model it is what the condition and so forth is does it make noise in the engine does it smoke and if so when idiling or under load? These are all items that need to be addressed before trying to give an estimated price and even your location can enter into the price. I am sure if you explain a little more some of the others will probably be happy to help you to the best of their ability. Good luck Richard
