Re: Replacing a head gasket - couple of questions.
Toora Stephen
03-10-2008 14:43:13
Thanks for the advice and replies. I manged to replace the gasket without any major issues. The engine started first go and ran as well as it ever has.
After a couple of hours though, I noticed a small amount of water coming out of the exhaust pipe. I now suspect my problems may be as alluded to by John (UK):
John (UK) said: (quoted from post at 05:13:02 03/09/08) You can remove the manifold with regular tools although it is easier with the special tool. Do not attempt to turn the engine unless the liners are clamped in place or they may move and damage the gaskets underneath and that is a major operation to replace them. Before you re-fit the Head you need to make sure that the Cylinder Liners stand proud of the Block by .005" to .011" or the Head gasket will leak into the water jacket or it may blow the Head gasket between cylinders.
When I took out the old gasket, it had obviously been replaced not too long ago. It didn't look much older than the one I put in, but was slightly damaged. Perhaps whoever did that job messed it up and so one of the problems that John refers to above occurred.
So I guess I now need to know more about these "gaskets underneath" and how to go about assessing or replacing them.
Then again, it may be too early to jump to that conclusion, so I'll keep an eye on it for a while first. After how long should I recheck the torque on the head bolts?
- TS
