Head surgery photos
Toora Stephen
03-10-2008 17:26:55
After taking off the rocker cover:
third party image
After taking off the head:
third party image
The head, underside view:
third party image
The tractor with its bits missing:
third party image
The new gasket goes on:
third party image
- TS
Bob (Aust)
03-16-2008 20:34:21
 Re: Head surgery photos in reply to Toora Stephen, 03-10-2008 17:26:55
1. Heat;
2. Socket and a long bar; or
3. If all else fails, a grinder, a drift and a big hammer!
Replacement bolts are available from any nut and bolt supplier. I bought high tensile, around $4.00 each.
Bob
Toora Stephen
03-16-2008 15:53:35
I tried to remove the bolt that attaches the radius rod to the axle, but it is stuck. I suspect it is slightly bent. Any suggestions?
- TS
Bob (Aust)
03-12-2008 16:13:56
John.
Any thoughts on how to straighten the radius rods?
They are hollow, fairly thin walls and one attempt I had at straightening one in a press a few years ago resulted in the tube flattening - but the curve remained! Not sure heat would give any better result.
Bob in Oz
Bob (Aust)
03-12-2008 16:10:03
With a seat like that, you may get air conditioning next Christmas..... .
:lol: :lol: :lol:
Bob in Oz
Toora Stephen
03-12-2008 14:34:20
 Re: Head surgery photos in reply to Bob (Aust), 03-10-2008 17:26:55
Bob (Aust) said: (quoted from post at 17:01:28 03/12/08)
Nice seat! Would make any grey Fergy purist cry! :lol:
Yeah. It was a Christmas present from the wife. The old one has not seen its last days, I assure you! ...but the new one is very comfy.
- TS
Irv (Ia)
03-12-2008 13:56:58
Bob, isn't that the bolt that holds it in?
Irv*
John (UK)
03-12-2008 08:04:10
When you remove the Head from a Standard engine NEVER turn the engine over without first fastening the cylinder liners down or they may move and damage the gasket underneath that they sit on and it may leak and it is a big job to change them. You should also check the liners of the engine that they stand proud of the Block face by .005" - .011" or it may leak compression across two cylinders and blow the head gasket between or it could blow into the water jacket.If you don't change the axle pin and bush and straighten the Radius rods, there is a danger that the axle beam will strike the bottom hose connection on the Radiator and break it.Changing the pin and bush etc. will make the tractor much more pleasant and easier to drive as it will bring all the dimensions back to the original specification...John
Bob (Aust)
03-11-2008 23:01:28
The photo is OK from my work computer, different ISP.
From the radius rod bend I suspect the front axle pivot pin bush has passed it's use by date, and whilst you're there, a new front crank shaft seal would not go amiss!!!
Toora Stephen
03-11-2008 20:39:17
Does anyone else have this problem? It seems OK to me.
- TS
Bob (Aust)
03-11-2008 16:17:41
I can't see your last photo. It is hosted at a different site (www.soakes.com) than the earlier photos (www.tractorshed.com) and won't open.
May be the soakes.com site is down or my ISP (Bigpond) is blocking the site?
Bob in Oz
Toora Stephen
03-11-2008 15:32:55
Here is a better pic:
third party image
All observations welcome!
- TS
Bob (Aust)
03-10-2008 22:03:54
Looking at the curve in the left radius rod in the second last photo, I suspect you have a fairly worn pivot bearing or pin in the front axle.
Whilst you have it stripped back that far you may care to change the axle pivot pin bush. I bought a pin and bush in the last week, think the bush was $15 and the pin $55 - approx Aus$70 for both. If you decide to change them, inspect the pin as it may not require replacement. Also, there are cheaper sources of parts supply than my local farm equipment dealer..... ...
Very hard to see but out of curiosity, is that a grease nipple I think I can see into the front axle pivot pin?
Bob in Oz
