TO 35 Axel seal
Tommiemb
03-12-2008 18:29:01
I am replacing a outer seal on the rear axel of my 58 massey and I have an installation question. The one I got from my massey dealer is not like the old one. This new one has a little circular tensioning spring built into the rubber to help it seal. My question is which way does the spring side face? Should it face the brake backing plate or the tractor? It will fit both ways.
Thanks
GMB
Tommiemb
03-15-2008 09:21:53
 Re: TO 35 Axel seal in reply to Bob (Aust), 03-12-2008 18:29:01
phil(va) said: (quoted from post at 21:55:25 03/13/08) As Rob said, the spring side goes toward the oil.
Thanks guys I am grateful for the help. I am putting it in tonight after some clean up inside. I will try to post some pics.
GMB
Tommiemb
03-13-2008 16:29:15
 Re: TO 35 Axel seal in reply to Irv (Ia), 03-12-2008 18:29:01
Jess al mighty that took some doing ;)
What do you think, top pic or bottom toward the brake backing plate?
The bottom one is the spring side.
Thanks 4 the help all.
GMB
phil(va)
03-13-2008 18:55:25
 Re: TO 35 Axel seal in reply to Tommiemb, 03-13-2008 16:29:15
Tommiemb
03-13-2008 16:25:31
 Re: TO 35 Axel seal in reply to gshadel, 03-12-2008 18:29:01
is this it? third party image
Which side goes to the brake backing side? third party image
Tommiemb
03-13-2008 16:19:06
I will try now.
Tommiemb
03-13-2008 16:18:13
 Re: TO 35 Axel seal in reply to Bendee, 03-12-2008 18:29:01
pictures ?
Tommiemb
03-13-2008 16:17:52
 Re: TO 35 Axel seal in reply to J Heitkemper, 03-12-2008 18:29:01
to put up
Tommiemb
03-13-2008 16:17:31
 Re: TO 35 Axel seal in reply to Duner Wi, 03-12-2008 18:29:01
number of posts
Tommiemb
03-13-2008 16:17:02
to post a certain
Tommiemb
03-13-2008 16:16:28
 Re: TO 35 Axel seal in reply to mark from the fort, 03-12-2008 18:29:01
Do I need
John (UK)
03-13-2008 11:36:50
 Re: TO 35 Axel seal in reply to Tommiemb, 03-12-2008 18:29:01
Look at the seal and then look at the sealing lip, that should face towards the oil it is trying to seal the tapered part should be away...John
Rob in OH*
03-12-2008 19:00:02
The spring side goes toward the fluid you are trying to seal.
