TO35 Lift Problem
PFG
08-27-1999 13:24:43
Cannot lift high enough to transport implments. Lift arms are not restricted, i.e. can lift to the top manually but will only lift about half-way using the system.
Jack in NB
09-05-1999 09:52:22
 Re: TO35 Lift Problem in reply to PFG, 08-27-1999 13:24:43
That's almost certainly adjustment. Is your position control (round knob) going all the way up (to the rear of the slide)?
If so, then the internal adjustments are out. They can be accessed through the right hand cover, after raising the right rear wheel 6" or so to keep the oil from running out. You'll need a shop manual for the adjustment procedure - we use the I&T manual, available from our hosts.
Not difficult - an hour's work.
Good luck!
