1959 to35
Doug Eaton
03-23-2008 12:27:39
Can anyone tell me how to get a control valve unstuck on my hydraulics.ThanksDD
John (UK)
03-23-2008 13:02:35
 Re: 1959 to35 in reply to Doug Eaton, 03-23-2008 12:27:39
Remove r/h round cover and you will see lever from control valve sticking up out of the oil, gently move this forwards, it is spring loaded so it will come back. If it wont move then the Pump needs to come out as most likely the washers on the Control Valve are worn and jamming it, this also causes loss of pressure so it won't lift as much as it did. The Control Valve linkage will also require resetting before the top is fitted. If you need more info on how to do this work, email me and I will send it out to you, just tell me as much as you can about what you have done..John
