Exhaust manifold gasket
Milton Kirkland
04-06-2001 20:06:16
Just ordered an exhaust manifold for my 1954 to30.The manifold came with two of the same gaskets.Am I supposed to use both gaskets or just one.Thanks ,Milton.
Ray,IN
04-06-2001 20:49:59
 Re: Exhaust manifold gasket in reply to Milton Kirkland, 04-06-2001 20:06:16
You have a spare now. One gasket is correct, no gasket cement is necessary. Be careful when tightening the bolts it's easy to crack/break this old cast iron. I check the manifold gasket surface for flatness and if warped much correct this by having the manifold ground just enough to clean it up to minimize breaking it. Used ones are available and expensive.
Milton Kirkland
04-07-2001 19:10:03
 Re: Re: Exhaust manifold gasket in reply to Ray,IN, 04-06-2001 20:49:59
Thanks Ray.Got another question.The new exhaust manifold is a little thicker than the old one.Can't use washers behind the nuts when installing it.Can I get by without using the washers,or do I need to replace the bolts with longer ones so that I can use washers?Thanks ,Milton K.
Ray,IN
04-08-2001 17:25:13
 Re: Re: Re: Exhaust manifold gasket in reply to Milton Kirkland, 04-07-2001 19:10:03
Washers should be used to minimize cracking or chipping the cast manifold. Try snugging down the manifold using the nuts, perhaps this will compress the gasket enough to then use washers, by removing 1 nut at a time. Then you may torque the bolts starting in the center and working to the ends. Thats how I'd do it, but my opinion and $1 will get you a cup of coffee somewhere. Enjoy, Ray
