TO-30 Tachometer
Charlie3933
04-08-2008 21:34:22
Hi
has anyone here installed a tach on a TO-30?
Jerry/MT
04-09-2008 09:53:05
 Re: TO-30 Tachometer in reply to Charlie3933, 04-08-2008 21:34:22
I put a small tac driven off the coil on my TO-30.
ferg0ne
04-09-2008 08:20:49
I have one on a To30 it was a NOS that I bought for $30.00
mark from the fort
04-12-2008 05:44:43
 Re: TO-30 Tachometer in reply to ferg0ne, 04-09-2008 08:20:49
I'll give ya $35.00 and you can keep the cable.
Ha Ha
Mark.
Good find..... ....
gshadel
04-09-2008 06:14:18
I installed a small digital tach on my TO-20. Several places sell them. I got mine from Northern Tools for ? maybe $40. Easy hook-
up it just uses a pickup wire that wraps around a plug wire, and a ground. I glued it to the dash. Well worth the cost and effort.
George
Grass Roots Farmer
04-17-2008 17:48:20
 Re: TO-30 Tachometer in reply to gshadel, 04-09-2008 06:14:18
I just bought a tachometer for my TO-20 from Northern Tools. Easy to install, but wondering about the "spark plug firing revolution setting." Does the spark plus fire twice per revolution, once per revolution or every other revolution? This setting determines the rpms. What should the actual rpm be at idle and mid-throttle? I"m getting high numbers with this tachometer. Thanks for setting me straight.
phil(va)
04-10-2008 09:31:21
George, did you doublecheck the tach you installed against a known good external tach? Was it close? I"m interested in installing one, but just wonder if they are accurate.
