Got my 30 running . Took it to the country and hooked up to the disk . She will run ands drive fine without a load . When I have the disk in the ground , it will pull ok for say 20 feet . Then it starts to loose power quickly and bog down and I get some black smoke . If I mash the clutch , it will rev back up to full speed in a few seconds . I have put a carb kit and adjusted the float per specs , cleaned the fuel bowl , elbow and lines . I seem to have at least the same flow as my Ford does . I have got to think that this thing is starving for fuel . I watched the govenor and it does keep it at full throttle with a load . I have got good spark . Believe me , I know ! Theonly thing I am not sure of is the wiring of the plugs from the distributor cap . When I bought it , it was wired this way when facing the motor from the distributor ..... Far left post to #1, Far right to # 4 , Near right to # 3 , Near left to # 2 . Now my I & T manual says firing order is 1 3 4 2 . The current setup does not in my mind match this . How should it be hooked up ? Any other ideas on the lack of power ? By the way , she will also bog down if I try to climb a hill with the disk on the tractor but raised of the ground . Thanks for the help and patience ! Ford Man
