Re: Sluge in center axel housing/pump/transmission - clea...
John (UK)
04-22-2008 13:25:33
The sludge forms when the oil isn't changed often enough, it should be changed every 12 months even if it doesn't turn a wheel as it deteriorates and the result is sludge. It should be changed when the oil is as hot as possible (should present no problem in Australia) and then it will wash out all the crap that is in there. make sure that the bottom of the gear shift lever isn't worn and allowing water in; and on the Draft Spring at the back of the Seat there is a felt washer under the spring, this is another place that water can get in. You can fit a rubber boot on the gear change lever but the Draft spring is more tricky and really needs to be stripped down and the parts replaced, if it isn't seized up.....John
