Ferguson TO 20 PTO Shaft
ERIC PELTIER
05-02-2008 19:16:40
I recently had to change the pto output shaft because it was leaking around the bearing. I appreciate everyones help with their input on what type of oil to use. I ended up using Rotella 15W40 and appears to be working really well with improved response on the 3pt lifts, and I mean much better, jumps up without hesitation. I however need to find out if there is a reason why it slowly drops over time with weight on it. I am not sure if there is a problem somewhere or if that is just normal. Also I thought I would let everyone know if they want the original shaft for restoring a show tractor as it is the original 1 1/8" shaft. If you are interested, feel free to contact me.
Thanks again,
Eric
John (UK)
05-03-2008 09:52:23
 Re: Ferguson TO 20 PTO Shaft in reply to ERIC PELTIER, 05-02-2008 19:16:40
As Phil says it is just fine. you must remember that it is not a sealed system and it will leak slowly. Never park the Tractor with an implement raised anyway, there is a danger that it may cause the Control Valve to stick, so rather than have all that problem, just lower it to the ground when you park up...John
phil(va)
05-03-2008 05:57:29
With any weight, say a scraper blade, if it holds up 10 minutes you can feel good about it. I have a 30 that will hold a dump bucket full of rocks up a couple of hours or more, but that is very exceptional.
Dennis(Ohio)
05-03-2008 04:09:31
This is a quote from John(UK) that he sent to me some time ago:"The factory test was 15 mins but really anything over 5 mins is good enough, the Pump can take care of any leaks at that drop rate."
marlowe
05-02-2008 20:10:36
they all do that
