Anyone succesfully change over a TO, TEA , or a TE-20 to 12 v?
mark arthur
04-13-2001 21:34:23
well i tried it today and after useing the one on this site for the farmall series. the thing wont even crank over. I have power to the voltmeter and the little red light comes on but when i try to crank it all goes out? was just wondering is someone could tell me how they wired it? I am stumped !!!
dennis
04-14-2001 09:05:45
 Re: anyone succesfully change over a TO, TEA , or a TE-20 to 12 v? in reply to mark arthur, 04-13-2001 21:34:23
check here for a diagram. the TO-30 pic is the same as a to-20
Jim
04-15-2001 07:14:55
 Re: Re: anyone succesfully change over a TO, TEA , or a TE-20 to 12 v? in reply to dennis, 04-14-2001 09:05:45
Mine was already converted to 12 V. However, while looking at these wiring diagrams the 6V. system has a Positive ground, and the 12 V system has a Neg. ground. I wonder why mine has been converted to 12 V. and still has a Positive ground?
Did you get yours converted and did you stay with Pos ground or switch to Neg ground with the conversion?
Maybe you or someone can help?
dennis
04-17-2001 05:54:25
 Re: Re: Re: anyone succesfully change over a TO, TEA , or a TE-20 to 12 v? in reply to Jim , 04-15-2001 07:14:55
mine was 12v when I got it 6 years ago. I THINK it's negative ground. I'll have to check - haven't looked at the battery for some time. I know that with a 6v system, it doesn't even make a difference on the polarity. I've run 6v model T's and A's either way for years. The ampmeter only needs to be reversed. AS for the 12v, I figure as long as you're not using an alternator, it shouldn't be any different with 12v. either.
Jim
04-17-2001 15:30:59
 Re: Re: Re: Re: anyone succesfully change over a TO, TEA , or a TE-20 to 12 v? in reply to dennis, 04-17-2001 05:54:25
Mine does have an Alternator, with the 12 Volt system including Positive ground. Since mine has an Alternator, has been converted to 12 Volt, I am assuming when a person swithces from 6V to 12V they remove the Generator and install an Alternator????? ????? Mine also has no regulator. Again I am guessing that an Alternator has got a built in voltage regulator, therefor not needing an external regulator.
Can anyone confirm this?
