Ferguson TEA-20
Jim Bevins
05-05-2008 18:19:22
I just bought a Ferguson TEA-20. It has no Starter.Can anyone supply me with a reference number,part number or anything that will help me in getting a starter? Thanks,Jim
Bill Brox
05-06-2008 14:17:32
 Re: Ferguson TEA-20 in reply to Jim Bevins, 05-05-2008 18:19:22
You have to be aware of that there can be 2 starters on a TEA 20, either 6 or 12 volts.
And, the difference lays in the bellhousing, meaning you can not use a 6 volt starter on a 12 volt TEA 20, and vice versa.
As for Sparex numbers, it is S.60354 for 6 volt tractors, and S.41136 for 12 volt tractors.
And, the 6 volt type can be used on a TE 20 with Continental engine if you put a 1/16" shim between the starter and engine surface where it mounts. According to Sparex.
All the best from Bill.
Bob (Aust)
05-05-2008 18:28:14
Jim. It was originally a Lucas M35G starter motor, 12 volt, nine (9) tooth drive.
A starter motor from a Continantal engine tractor (TE20, TO20, TO30) will NOT fit.
Not sure where you are, but replacement starters are readily available, Massey Ferguson Part Nos 25038, 829803M91, Sparex Part No S.41136.
Also available from this site.
Bob in Oz
