Distributor which Direction advancess, retards
Jim kwik
05-06-2008 22:35:59
Have a TO 30, While putting on oil pan gasket. Cleaned my flywheel timing marks up real good. Got it set on 6* .Had to rotate dist. back (counter clockwise ) about 3/4 inch to get it to static time with test lite. Just wondering did I Retard or advance it. waiting on radiator hose so Haven't run yet to see if it made any difference. Thanks.Jr
Jim kwik
05-07-2008 16:08:31
 Re: Distributor which Direction advancess, retards in reply to Jim kwik, 05-06-2008 22:35:59
Thanks ,Jerry. I couldn't see the marks good enough before to use a timing light. So I cleaned it up real good and put bright paint on toothpick and painted degree marks ,thanks again
Jerry/MT
05-07-2008 10:39:55
The distributor shaft rotates in the counterclockwise direction so you retarded the spark from it"s original position if you moved it counterclockwise.
