Ferguson Tranny Leak
Clint
04-15-2001 11:32:17
I have a Ferguson TO-30 that is leaking hydraulic fluid at the cotter pin that hangs down from the tranny in front of the drain plug. THough it isnt leaking much is this or could this be a serious problem and how much and how long would it be to have fixed.
dennis
04-17-2001 06:03:05
 Re: Ferguson Tranny Leak in reply to Clint, 04-15-2001 11:32:17
odds are that it's the rear main seal on the engine that's leaking. That's where they show up. It's a major overhaul to fix. If it's not dumping tremendous amounts don't worry about it.
matt jones
04-15-2001 14:41:25
As long as it's not alot of fluid i wouldn't worry about it. There is a couple of seals and gaskets on the transmission drive gears. The only way to replace is to split the tractor. Parts are cheap but alot of labor. Wait until clutch needs replacing and replace then or when you have to split it for another reason.
