Ferguson TEA20 Rod Journal Size
Dwayne Russell
05-18-2008 11:41:17
Does anyone know what the crankshaft and rod journals should mic at for a 1953 Ferguson TEA20 (Standard Engine - English Built ). I picked up a nasty rod knock so I shut the engine down. Removing the pan shows the rod journals have been stamped, so the engine was rebuilt at sometime. The rod bearings were pounded to death so I suspect the crank is probably undersized and the wrong rod bearings were used.
Anyway if someone can tell me what they should mic I would really appreciate it. I also need to locate good bearings. Any suggestions?
Please email me direct at dwaynerussell@earthlink.net
Bob (Aust)
05-19-2008 01:11:10
 Re: Ferguson TEA20 Rod Journal Size in reply to Dwayne Russell, 05-18-2008 11:41:17
Dwayne. Check your email. Bob in Oz
Bob (Aust)
05-18-2008 21:05:54
Dwayne.
I'll scan the manual engine specs page and email to you this evening.
Good luck
Bob in Oz
'53 TEA20
Bob (Aust)
05-18-2008 13:09:59
Big End:
Crankpin Diameter: 2.0866 - 2.0861 Clearance New .0024 - .0006
Bearing Bore (fitted): 2.0885 - 2.0872
Connecting Rod bore: 2,2335 - 2.2327
Radial Thickness of bearing: .07275 - .07250
Dwayne Russell
05-18-2008 13:23:23
 Re: Ferguson TEA20 Rod Journal Size in reply to Bob (Aust), 05-18-2008 13:09:59
Bob
Thanks so much. I will get out there and run a mic over the journals and see what were dealing with. I was hoping to get through the summer with this tractor and then start a full restoration this winter when the weather is cold and I have time to work on it.
Dwayne
