Drawbar/Quick Hitch question
Michael William
04-18-2001 12:08:26
I got a Stevens Ag Parts Catalog and noticed they have a thing called a quick hitch which allows you to hook up a trailer, hooks, etc. What about a drawbar? Is it the same thing? Mine has the clevis, but not the drawbar. Suggestions on whether I should get the quick hitch or a drawbar would be appreciated. I plan on using it to pull a trailer that will have firewood and such in it. By the way, I ordered the Zane Thang and should get it this week. I appreciate all the help!
Michael Williams
Ray,IN
04-18-2001 22:04:21
 Re: Drawbar/Quick Hitch question in reply to Michael Williams, 04-18-2001 12:08:26
I made a bracket that holds the TPH drawbar so it won't rotate, and bolted a 2in. ball on the drawbar. The bracket is merely a 10in. length of 1 1/2in. angle iron with a 3/4in. hole in one end to bolt to the drawbar, and the other end has a 1/2in. hole that holds a j bolt. the j bolt fastens to a bottom arm, the bracket is bolted underneath both the drawbar and the bottom arm. I have used this for 12yrs. now and it always works well, plus it's cheap.
