Front pump pulley available?
DavePA
04-21-2001 20:53:28
I was to have a hydro. pump mounted on the front of my TO-30 to simplify loader use and to free up rear pump for 3 point work. mechanic called and said factory front pulley would not adapt to pump assem. due to (spoke design?) on inside of pulley. At present I'm not sure what to look for but was told pulley might be the same on some back hoes. I have not been told what brand of pump he had ordered but if some one has experienced this problem and knows a vender who handles the pulley..... thanks again DavePA
dennis
04-22-2001 09:10:23
 Re: front pump pulley available? in reply to DavePA, 04-21-2001 20:53:28
go to any dealer that sells TISCO parts and you can get that pulley. most all pump parts are available there. I went to my local JD dealer for mine but they are also avail at my MF dealer.
DavePA
04-22-2001 13:13:31
 Re: Re: front pump pulley available? in reply to dennis, 04-22-2001 09:10:23
thanks for the response--Where do I find a tisco dealer and or web site? If JD and MF both carry the pulley needed what information must I provide, do all front mounted pumps use the same pulley regardless of manufacture? Keep in mind I have not seen the pulley so I have to rely on someone who has already been there. thanks again DavePA
