Fergusen TO-20 Carb Adjust after rebuild
DLW
04-27-2001 07:37:45
I just rebuilt my Marvel-Schebler TSX361A carburetor. There were no instructions with the kit and I don't have a manual. After I reassembled and installed the carb, I seated both screws (the big knurled knob and the little screw on the side) all the way in, and then backed them out 2 1/2 turns. It started right up. But I know this isn't the correct setting. Can anyone tell me a good setting for these two screws as an initial setting before fine tuning?
Ray,IN
04-27-2001 20:55:14
 Re: Fergusen TO-20 Carb Adjust after rebuild in reply to DLW, 04-27-2001 07:37:45
About 4 days back we discussed this. The idle screw is opened 7/8 turn initial adj. The main jet(power jet) is opened 1 1/4 turns initial adj. Fine tune at operating temp. The Ferguson engine uses fuel to help cool the valves under heavy load, so never operate with the main jet less than 1 full turn open. Ideally the main jet is adjusted with the engine loaded, as with plowing. I plow 20ft. and make a small adj.& repeat this until I find the spot that pulls best without loading up. That my method.
Ray,IN
04-27-2001 20:53:57
Ray,IN
04-27-2001 20:51:59
Ray,IN
04-27-2001 20:51:21
Ray,IN
04-27-2001 20:51:01
Ray,IN
04-28-2001 20:47:11
 Re: Re: Fergusen TO-20 Carb Adjust after rebuild in reply to Ray,IN, 04-27-2001 20:51:01
Well, Obviously the sever error msg. I was getting was an error also. Thats life!
