FERGUSON TO-20
BRIAN AYCOCK
05-01-2001 14:07:14
HELP I BOUGHT WHAT I THOUGHT WAS A FORD 8N. TURNED OUT TO BE A FERGUSON TO-20 I THINK. SOME KIND SOUL HAS REMOVED THE TAG ON THE MOTOR BLOCK.DOES ANYONE KNOW WHERE I CAN GET A MANYEL FOR THIS. I HAVE GOTTEN TUNE UP PARTS RINGS AND ROD BEARINGS FINALY FOR IT. ALL THE PARTS BOOKS INDICATE IT IS A TO-20 IS THERE ANYWAY TO TELL FOR SURE? THANKS BRIAN
Joe in MO
08-22-2001 14:53:11
 Re: FERGUSON TO-20 in reply to BRIAN AYCOCK, 05-01-2001 14:07:14
By the way if you see an old thresher's show or antique tractor pull, look for booths with manuals
there, I found one for my to20 for 10 dollars and it's helped a lot.
Alan
05-02-2001 21:52:41
Brian: If you need good info RE: your tractor, Talk to Ray in Indiana on the Harry Ferguson discussion board. He has helped me with questions on several occasions and knows who to put you in touch with.
Clint
05-01-2001 15:52:32
The telephone number for Cranken Hope Publications is 724-459-8853 call them up and tell them that you need a shop manual for a Ferguson TO-20
Bobby
05-02-2001 19:48:56
 Re: Re: FERGUSON TO-20 in reply to Clint, 05-01-2001 15:52:32
look at the large casting on the block near the oil pan if it is Z120 it is a 20. also the filter went in the pan. If it is Z134 it is a TO-30 the oil filter will be out side the block
dennis
05-03-2001 18:49:13
 Re: Re: Re: FERGUSON TO-20 in reply to Bobby, 05-02-2001 19:48:56
TO30 has a Z129. Filter is on the outside.
The to35 has the z134, I believe.
Clint
05-01-2001 14:51:58
I own a TO-20 and you have come to the right place for info the people here are quite knowledgable about their tractors and they are all eager to help. I own a TO-20 and on the left side of the block there will be a series of #'s if it starts with Z120 it is a TO-20. There is a manual that you can get from a company in PA. and I dont have their phone # in front of me right now but I can have it for you before the night is over they have the manuals for the TO-20 and they are reprints from the original factory literature the total cost w/ S&H will be $22.50
wes
05-01-2001 14:12:04
up by the steering wheel their should be a tag pop rivetid where the wheel shaft comes out of the bulkhead
