Dual clutch on an FE35
David Hall
05-03-2001 19:24:27
The serial number (SDM123719) of my FE35 leads me to believe that it has the dual clutch "feature".
Can anybody tell me how I can verify this, what the fuction of the dual clutch is and how I can make use of it?
Thanks
David Hall
Wellington, New Zealand
Paul in NM
05-04-2001 17:50:10
 Re: Dual clutch on an FE35 in reply to David Hall, 05-03-2001 19:24:27
In the SN, S=Standard chassis, D=Diesel engine, and M=Dual clutch.
Paul
Chuck (CA)
05-03-2001 21:31:13
Hello David,
This is a bit of speculation on my part, and hopefully someone will correct me if I'm wrong:
The '35 has a live PTO. How it works is, if you push the clutch partially in, the tractor stops but the PTO keeps on agoin'. Push the clutch all the way in, and the PTO stops also. (Hence, dual clutch.)
My TO30 doesn't have a live PTO... When I push the clutch, everything stops; tractor and PTO.
Hope this explains it.
Chuck (CA)
