Seals,T30
Arnold M. Rhoad
05-06-2001 11:07:26
Having both rear seals leaking,hearing about the sure seal-found a massy rep (dealer)?? with in 30 miles,and after removing parts found the shrink retainer coller to hub diminsions were standard found C/R seal 27370 fit nicley--also installed C/R 19643 where the OEM seal rides. Cleaned the oil soaked brake shoes ith ether(starting fluid) and used 120 grit emery cloth to remove some of the brakelining ..Workes great. Two seals per side cost about 25 per side.
