TO 20 not getting gas to combustion chamber
BWL
05-11-2001 15:05:52
I have a to-20 that turns over and sparks but is not getting any gas into the combustion chamber, The carb was rebuilt, all the all the jets are open, the fuel is new, and it has a spark. After cranking with throttle wide open the plugs are completely dry. Any ideas?
Joe in NY
05-11-2001 19:07:47
 Re: TO 20 not getting gas to combustion chamber in reply to BWL, 05-11-2001 15:05:52
Try disconnecting the fuel line at the carb. See if you have fuel flow. If not check fuel filters in the top of the fuel bowl and in the tank.
Most likely that is were you'll find the problem.
Good luck,
Joe in NY
rod
05-11-2001 17:38:28
follow the fuel flow make sure you have fuel to the carb by opening the drain. If you have good fuel flow it is in the carb itself you can also try a shot of ether in the air intake to see if it kicks. Is your carb to manifold gasket the right one. Let us know what happens. PS I have the Operators and Service manual for the TO 20 for sale so email me direct if you need one. Also check out>Link
regards
rod>Link
