Correct carb (air and gas) adjustment settings for TO-30
steve
05-15-2001 10:33:06
I was wondering what the correct carborater setting is for the gas and air adjustments on my TO-30 tractor. I do not know the exact model of the carb.
The air adjustment is a small screw facing out that you adjust with a screw driver.
The gas adjustment is on the top right hand side that can be adjusted by hand.
thanks
steve
Ray,In
05-15-2001 20:48:56
 Re: Correct carb (air and gas) adjustment settings for TO-30 in reply to steve, 05-15-2001 10:33:06
The idling air adjustment is 7/8 of a turn open. Fine adj. after engine warmup. The main jet adjustment is 1 1/4 turns open. Again, fine adjust after warmup-and under load. Do NOT operate at less than one full turn open! The valves depend of fuel to assist cooling them under heavy load conditions. A wise investment is buying a owners manual, I refer to mine almost every week, it's thin but packed with info. Purchase one from the local MF dealer.
