BRONZE/COPPER material in oil pan \\TO 30
jimmy
05-16-2001 18:42:34
i resently had the pan off my TO 30 I FOUND 3 COPPER/ BRONZE (BUSHING) CHUNKS ABOUT THE SIZE OF A THUMBNAIL IN THE PAN .COULD THIS BE WRIST PIN BUSHING, OR THRUST ON CRANKSHAFT.ONE PIECE LOOKS TO TAKE SHAPE OF WRIST PIN BUSHING ,SHOULD I PULL IT DOWN NOW AND CHECK IT OUT OR DRIVE IT ,IT HAS ALWAYS HAD A TAPPING NOISE BUT IT DOESNT KNOCK AT ALL ,IT PULLS LIKE A MULE ,I HAVE ADJUSTED THE VALVES SINCE I BOUGHT IT LAST SUMMER TO TRY TO GET THE TAPPING OUT IS THIS NORMAL FOR A FERGIE ?????
Bobby
05-18-2001 18:22:44
 Re: BRONZE/COPPER material in oil pan \\TO 30 in reply to jimmy , 05-16-2001 18:42:34
you might look at the rocker arms. if it had replacement arms there could be a chance the shaft is not indexed right and walked the bushings out.
Jim-PA
05-17-2001 03:05:38
I think you are right about the wrist pin bushings. Tear into her and find out for sure. Bushings are cheep, engines are not.
Ray,IN
05-16-2001 20:47:27
Usually valve noise is minimal or not heard. I would find out where the pieces you found came from ASAP! The time spent investigating is less that a total rebuild, and considerably less expensive.
