Generator output
Tania/Wis
05-27-2001 07:09:16
My TE20 doesn't seem to be charging up to par. Can anyone give me an idea what the readings should be at an idle, ect. Still the 6volt system with a 9volt battery. Did find a manual for it, gives info on the electrical system, even how to make repairs on the generator, ect but not how to check output. Thanks
Ray,IN
05-28-2001 18:58:37
 Re: generator output in reply to Tania/Wis, 05-27-2001 07:09:16
The 6v system will not charge correctly connected to a 9v battery. Return to the 6v, 80AH battery and you will be able to measure charging voltage/amperage like you inquired about. The 6v generator will supply 16-19 amps at operating temperature. The 3rd brush will vary the charging rate by moving it, however moving it to the maximum will cause the voltage regulator to fail in a short while. Hope this helps!
