Ferguson30/draft control
Jeff Ware
06-08-2001 09:58:15
Is there any way to control (turn on or off)the draft control on three pt. hitch? I am having trouble keeping my bush hog level. It tends to over correct either pulling up too high or driving it into the ground.
Michael Williams
06-08-2001 11:58:03
 Re: ferguson30/draft control in reply to Jeff Ware, 06-08-2001 09:58:15
Jeff, I recently got the Zane Thang and it really works. I had the same trouble as you--the implement not staying where I wanted it to stay. The Zane Thang takes care of the problem. It works for me!
Chuck (CA)
06-08-2001 10:13:26
Jeff,
I've had fairly good luck with limiter chains. You can buy these for 20-30 bucks at most farm supply stores, or search the archives on the Ford N board for making your own. Also, Zane Sherman (One of our sponsors) has made a device called a Zane Thang which gives you position control for your '30. All I've read about it has been very positive.
Good Luck,
Chuck
