Block crack at #4 cyl.
george herold
06-11-2001 19:19:56
Well I did it. I bought a TE-20 the other day. It runs fine but has water in oil. I assume this is due to the crack I see, while looking up through the oil pan hole, in the block by the number 4 cylinder. There are signs of an attempted weld patch. I assume this is the leak point. all gaskets looked fine and there is no visible crack in the head. I thought I would take the block out and have then have someone add more material all around the cracked area (really two small cracks). And then have the block milled out. First do you have any other suggestions. And second how much should I expect to pay for this to have it done right?
Thanks George
