1951 TO-20 makes clicking noise.
Daniel Klingens
06-12-2001 07:41:28
My TO-20 makes a constant clicking sound when running. It seems to be affected by the rpms. When I rev the tractor up the clicking noise seems to get faster. I think that it might be a valve smacking a rocker arm. The tractor also has a slight spit and sputter to it. I would like to get her running smooth. Any help will be greatly appreciated.
jimmy
06-13-2001 17:50:54
 Re: 1951 TO-20 makes clicking noise. in reply to Daniel Klingensmith, 06-12-2001 07:41:28
MY TO 30 DOES THE SAME ,BUT I FOUND SOME BRONZE BEARING / BUSHING MATERIAL IN THE THE PAN .IM NOT SURE AT THIS TIME THAT ITS RIST PIN NOISE OR NOT BUT HAVE BEEN TOLD THAT THE MATERIAL COULD ONLY BE RIST PIN BUSHING . BUT THE NOISE IS LIKE YOU SAY A TAPPPPING.... NOT A KNOCK SO I NEED HELP ALSO
jay
06-17-2001 15:23:23
 Re: Re: 1951 TO-20 makes clicking noise. in reply to jimmy , 06-13-2001 17:50:54
try shorting out the cylinders one at a time if it is a wrist pin the noise will double up when you short it out..... ..... jay
rod
06-12-2001 11:24:42
maybe a broken valve spring? IF you put an old short piece of garden hose or such against the valve cover then listen at the end of it you may isolate the sound better. regards
rod
stevie_alc
06-12-2001 20:34:30
 Re: Re: 1951 TO-20 makes clicking noise. in reply to rod, 06-12-2001 11:24:42
Daniel;
My TO-30 is doing the same thing. Sounds like a valve is not adjusted right. Have checked valve clearence several times and have had good help in doing so. Not sure what it could be. Anybody have and ideas.
Thanks
Daniel Klingensmith
06-14-2001 20:45:07
 Re: Re: Re: 1951 TO-20 makes clicking noise. in reply to stevie_alc, 06-12-2001 20:34:30
Thanks guys for your input.
