Massey Ferguson
Bob Voreis
06-12-2001 15:35:21
I have a TO35, with a broken cover that holds the 3 point levers, I have a MF65 with a blown engine can I use the motor and front end of the TO35 and connect to matching rear parts on the MF65? If someone knows the answer please respond soon, I need to have one of the tractors working very soon. Thank You for your response
Jack in NB
06-13-2001 06:04:12
 Re: Massey Ferguson in reply to Bob Voreis, 06-12-2001 15:35:21
Hello Bob -
The transmission and differential cases should be the same. Gear ratios might be different, but that should not matter. Don't know whether all the holes for clutch and radius rod mounting will match, but take a look.
The steering boxes should have the same bottom bolt pattern where they mount on the trans case, so they should swap ok.
Now that would be an interesting set-up! What will you call it?
Ray,IN
06-12-2001 20:40:22
Try the parts suppliers at the left for the cover you mentioned. If they cannot help, look here:
