Cracked Head, What do you think? Please!
Rott
06-15-2001 07:26:33
The head on my TO 30 is cracked in 4 places. The cracks are in the space above the cylinders where the plugs come thru. I was having trouble with getting water in the oil pan so took it off and had it checked at the local shop and they showed me the cracks and 3 in the block. But when I took the head off there was no water above the pistons and the tractor ran just fine except for getting hot, which makes me belive that the water was getting in from the block and not the head. After talking to a few old timers in town that have worked on these tractors all their life they said to fix the block and put the head back on it would be ok. Just looking for a few more opinions, Thanks!
Ray,In
06-15-2001 21:02:36
 Re: Cracked Head, What do you think? Please! in reply to Rott, 06-15-2001 07:26:33
Check the cyl. liner seals at the bottom. The liners are wet, and some guys have reported this as the source of the water in the oil. You may be able to remove the pan and inspect the liners' bottom seal after pressurizing the coolant system. Try researching the archives for past discussions of this problem. Some have used liquid glass- with good/bad results. Most guys agree that properly repairing the source of the problem is best though. That's my suggestions.
