1950-to20-seals
Stormin
09-14-1999 03:26:21
Need some info-Rear axle seals are leaking.How to remove and replace them? anyone---thanks-stormin
ZANE
10-03-1999 04:50:46
 Re: 1950-to20-seals in reply to Stormin, 09-14-1999 03:26:21
This is in one of my files and I did it for the Ford owners but I have a TO 20 and have fixed the oil leaking problem on it years ago with this fix.
If the hub is not extremely tight so that you have to have a puller to get it off I think you can replace the seal yourself. If the hub is tight that is a good sign you might get it to stop leaking.The problem with the 48 8N is that it does not have an inner seal like the 51 and 52 do. If the hub is loose on the axle and it can't be tightened because of the spline being worn too much to allow any more tightening then you will not be able to stop the leak the conventional way unless you replace the axle and hub. I hope that is not the case.
If the axle is worn too much to allow it to be tightened then you might consider my fix for the leak and leave the hub loose a few more years. To fix the leak my unconventional way you pull the axle away from the axle housing about 6 or 8 inches and wrap the axle for about 6 inches from the outer end of the axle that is exposed Wipe all the oil from the housing and then take a caulking tube full of silicone glue and pump it into the void between the axle and the housing. Keep the hub as close to the housing as you can till you get the silicone pumped in.Use the whole tube and then replace the axle into the housing and replace the bolts etc. Let the silicone cure overnight and then you can go about using the tractor. Be sure that the oil in the rearend etc is not over full as this will contribute to the axle leaking.
Terry
09-14-1999 19:44:17
The rear axles have to be pulled and the bearings and collars have to be pressed off in
order to replace the oil seals which are located on the outer side of the axle retainer
assembly. I replaced the ones on my 1950 TO-20 about 2 years ago. The local auto repair
shop pressed the bearings off and back on for me. The rest is fairly simple to do. An I&T
shop manual is a good place for information on adjusting the rear axle bearings.Good
luck,Terry
