Cracked Blocks Z120 and Z129?
Greg, MI
06-22-2001 17:17:00
Do the 120s crack more often than the 129s or did continental have this problem strightened out by then? What I mean is, is it more common to find a cracked block in one or the other. Or is the cracking problem found in a diffrent brand of engine used in the Fergison?
peterc
06-23-2001 17:13:27
 Re: Cracked Blocks Z120 and Z129? in reply to Greg, MI, 06-22-2001 17:17:00
the continental blocks are noted for cracking in the webs between the cylinders both top and bottom. the top is not so bad because the head gasket usually seals them but the bottom is where you get water in the oil problems. they can be repaired by a good welder.
Willie KY
06-22-2001 17:28:30
Are there any pictures out there that I can look at to get an Idea where these blocks crack? or can anyone discribe where the crack?
Dan in LA
06-23-2001 07:57:29
 Re: Re: Cracked Blocks Z120 and Z129? in reply to Willie KY, 06-22-2001 17:28:30
Send me your e-mail address and I will send you photos of cracked Z120 blocks
Dan
