1951 TO30
mike
07-01-2001 12:31:24
IAM LOOKING TO BUY MY FIRST TRACTOR A FERGUSON TO-30. THIS TRACTOR LOOKS OK AND RUNS GOOD IT COMES WITH A BRUSH HOG A PULL DISK AND A DIRT SCOOP. THE OWNERS ARE ASKING 2,200 FOR ALL IT SOUNDS LIKE A GOOD DEAL. BUT WHAT ARE THE THINGS I SHOULD BE LOOKING FOR TO MAKE SURE THIS IS A GOOD DEAL.
Larry
07-02-2001 10:12:21
 Re: 1951 TO30 in reply to mike, 07-01-2001 12:31:24
I bought a 1953 TO30 several years ago. It now has a completely rebuilt engine, new fuel tank, new radiator. Some good ole boy farmers like to tack a tractor together with silicone caulk so it'll run fine for an few hours, until the caulk starts to fail.
Make sure the governor works, and look for *anything* odd in the water and oil. Look for leaks, too.
It sounds like a terrific deal, if it's a solid TO30.
Larry
Ray,IN
07-01-2001 22:54:15
In addition to Williams water in oil tip; remove the radiator cap and look for continous bubbles, oil,heavy rust and core damage. Ask to drive/operate, to observe smoke from tailpipe, blue or white is bad, some black is normal. Rear tires/rims are expensive to replace, check for cracks,breaks,fluid leakage(if filled) that ruins rims. If you really want to investigate the engine, run a compression check. That's my two cents worth.
william l. brown
07-01-2001 12:43:57
MIKE, make sure there is no water in the oil.
has the engine ever been overhauled?
i have a TO-20,and it has water in the oil,
but it still runs, and it seems to be ok except for this. the price sounds good,
but maybe too good?
william
mike
07-01-2001 20:42:41
 Re: Re: 1951 TO30 in reply to william l. brown, 07-01-2001 12:43:57
WILL MY 1951 IS A 1953 I WENT AND GAVE IT ONE LAST LOOK TODAY NO OIL IN THE WATER. AND IT RUNS GOOD MY MAIN CONCERN IS IT FEELS A LITTLE LIGHT IN THE FRONT END. WHAT CAN I DO TO WEIGHT IT DOWN IN THE FRONT?
william l. brown
07-02-2001 08:06:09
 Re: Re: Re: 1951 TO30 in reply to mike, 07-01-2001 20:42:41
MIKE, i made a weight from square tubing.
(large) filled it with concrete,and
welded an end on it with two straps of
steel, and bolted it under the bumper.
yes, mine had a bumper when i bought it.
this helps the problem when you pick up a heavy implement on the 3 point.
william
