6 volt western
Bretoner
07-05-2001 08:39:56
Hi,
I just cleaned and repaired a 6 volt western generator off of an early 50's farmall. Spinning it with an electric motor I got a 11.3 v output on my vom? I know some car alts can put out 18-19 volts when full fielded but 11.3 seems high for a 6 volt, is this normal? I spun it a 1600 rpm for less than 30 seconds. Sorry for the long post, any help would be greatly appreciated
Bret.
Ray,IN
07-05-2001 21:09:34
 Re: 6 volt western in reply to Bretoner, 07-05-2001 08:39:56
You should ask the guys on the Farmall & IHC forum. They will likely have the answer. Good Luck!
Bretoner
07-05-2001 21:24:21
 Re: Re: 6 volt western in reply to Ray,IN, 07-05-2001 21:09:34
Sorry, got my forums mixed up. But isn't a 6 volt gen. a 6 volt gen no matter what machine it's on.For what it's worth I think the western is a delco with the weestern name on it. thanks
Bret
Ray,IN
07-07-2001 20:07:19
 Re: Re: Re: 6 volt western in reply to Bretoner, 07-05-2001 21:24:21
It depends on the application. I can tell you that the 6V generator H.Ferguson tractors use are capable of 16-19 ampheres output maximum. It has a 3rd brush that is movable to regulate output. I've tried running the max. output and it shortens the battery life when used for all except short intervals. Perhaps you can set back the 3rd brush to reduce the output.
